Scandi grinds vs normal V-grinds for field sharpening
One thing keeps bugging me. A lot of times it's said that a scandi (zero-bevel) grind (read Mora knife) is 'easy' to sharpen since you can just put it flat on a stone so it's easy to keep a constant edge.
But, don't you then always need to removing a lot of metal just to get the knife sharp again? And wouldn't you need a perfectly flat stone which is not easy to find in the field?
See the small illustration. The edges are a bit 'overdone' - The red is what I think is removed when sharpening.
Most of my knives have a 30 degr. back bevel and 40 degr. edge (inclusive). If I would need to touch up that in the field, I could pick up probably any rock, and give it a few swipes????
I've posted this here since I would like to view it in the perspective of field sharpening, so without the Sharpmaker or Apex Pro.
Any thoughts on this?
Thanks,
Ted
Yep, exactly.
yep you need to remove a lot of metal.
There are not so many people that seriously consider sharpening their knife on a stone "picked from the stream". The "easy single bevel sharpening thing" is that it is easier to get a nice edge from a conventionnal stone when under stress, tired etc ...
Anyway assuming you can't sharpen it to a "single bevel" you can still create a small bevel to restore edge as you would do with any other knife.
You can do the same thing with a v-grind with a secondary bevel with a little imagination, making a field capable jig for a touchup is trivial, a piece of wood under the spine for example.
The best responce to this I ever saw was by my brother as he *HATES* puukko grinds and I mentioned this off hand to him one time, more as a joke than anything else.
He takes a simple benchstone sets it on an angle to the wall (stump/rock, etc.), and says "Sharpen on one side until you get a burr, walk around and sharpen the other side. Done." Making field v-rods is trivial.
In regards to the built in angle guide, David Boye does this with his fixed blade hunters, and I think the one piece ones by making the guards part of the guide.
Field sharpening though is much more hyped than reality, unless you really blunt a knife by cutting sod or similar, with proper use of microbevels you can restore an edge with 1-2 passes on a hone.
I usually run cutting trials on cardboard and such down to <5% of optimal sharpness, very blunt, it takes 1-2 passes on a sharpmaker to restore shaving sharpness.
-Cliff
