Scandi Sharpening?
jeffbird
What is the correct way to sharpen a Scandi grind?
Seems like to maintain the original angles, the stone has to cover the full face of the original bevel, otherwise cut a secondary bevel. The original bevel is flat, not convex.
Thanks.
Lay the bevel on the stone and sharpen until you reach the desired edge and finish. It's like having a built in angle guide. Be mindful of finger pressure though, where you place pressure is where the metal will be removed.
Simplest of all blades to sharpen. Just lay it flat and scrub away, whatever technique you prefer.
