Scarches On Bolsters
Razor
I just bought a new olivewood Boker copperhead. Man you would not believe the fit and finish on these knives. I just had to carry it, so yesterday I put it in my pocket with my BM Rift clipped to my pocket. I guess when I was driving and sitting down the BM scratch the bolster on the Boker purty good. Could I take my demeral tool and polish them out? Would their be a better way? I know it won't hurt the knife but wanted to show it off before it gets scratch up.
Assuming the bolsters are either nickel or brass, it's quite easy to make 'em shine again. Some wet/dry sandpaper wrapped around a soft(ish) rubber eraser works very well as a sanding block. Depending on how deep the scratches are, anything in the 400 - 1000+ grit range should clean them up pretty fast. And 2000+ grit will start mirror-polishing it. Nickel and brass bolsters are very soft by comparison to the SiC/AlOx abrasive of the sandpaper, so it works fast. Follow the 2000+ grit sandpaper with some Flitz/Simichrome polishing paste on a soft & clean rag.
You might also be able to use a Scotch-Brite pad to clean up the scratches, though I can't guarantee it'll take it to the same high polish as the high-grit sandpaper.
BTW, the Dremel might work, with a soft cotton buffing wheel and some polishing compound, but only if the scratches are very, very light. Keep the wheel moving; don't linger in one spot for more than a second or two (overheating/scorching), and keep the wheel away from synthetic handle materials like Delrin/plastic (it'll melt them quick). If the scratches are very deep, I'd avoid using the Dremel with anything more abrasive (more potential to do damage, than repair). The safest option, to me, would be the sandpaper by hand.
David
If the bolster is mirror finish, dremel or wheel buffers are by far the easiest to polish out scratches.
I would start at felt polishing wheels / tips with very high grit abrasives.
1 micron diamond spray on felt tip or loose cloth does wonders.
If it doesn't remove the scratch, move down to coarser grit.
The thing about powered tools is that if you start at a low grit you are not familiar with,
you could potentially do some damage (introduce a dimple, mess with temper, etc.)
And since it only takes brief time to polish out, it is almost always a good idea to start high then go low (then back high).
Thanks and good luck.
They are mirror polished. Thanks everyone for the advice.
