The CRK factory edge is created on a belt sander. It is then buffed on a felt wheel charged with polishing medium. I believe the slack portion of the belt is used. This, in combination with the felt wheel, provides a convex edge, which is very durable.
The Sharpmaker is a different system than that used by CRK. The results will not be identical. However, this will not be noticeable if done correctly. When using the Sharpmaker correctly, you will not be hitting the side of the bevel. You should be just sharpening the very edge - that fine line on the edge of the blade. A magnifier will show that you have created a second bevel along the edge. Otherwise, it should look the same.
Definitely do not start with the Sebenza. Use slow strokes and only the flats, not the corners. First, touch up the blade to 1/2 inch of the tip. Then do the tip very carefully and don't let the blade slide off the flat - it will lose the point, if you do.
And don't worry about it. I boogered a blade pretty bad in my learning experience. CRK resharpens for free and it came back wicked sharp. Good luck.
