- Sep 28, 2014
Okay, I want a field sharpener that I can use on my Mora carbon Scandi grind. I like the DMT Diafolds because:
1. No lubricant required.
2. Stays flat.
3. Interrupted surface doesn't require flushing as often as continuous (a la EZE Lap) in case water is scarce.
First, any suggestions for better options I haven't considered?
Second, what grits? I want to be able to restore a dull blade pretty quick, or just do touch-ups. I like a bit of tooth in the finish. I've heard that the DMT grits are more coarse than some others, so I wasn't sure.
Thanks!
2. Stays flat.
Thanks!
