Schrade Handbook
Codger_64
Moderator
Schrade, from as early as the 1926 catalog "E", took it upon themselves to help educate the public about knives. From time to time, they added publications with this in mind.
This information is posted online elsewhere with illustrations, and I'll give that link at the bottom. It was derived from a Schrade publication, another version of which was published in 1997. Larry, is the '97 version on the Schrades-R.us website? Well, I just thought you fellows might be able to use some of this info, so here is a brief copy/paste. Enjoy!
The Blades Used in Schrade Knives
All of the materials that go into Schrade knives are of the highest quality and have been selected for use after extensive testing. The most important part of a knife is the blade and the steel that it is made from. In selecting the steel for a knife blade we look at two main attributes:
The ability of the blade to hold an edge when properly heat treated, and:
The ease of resharpening once the edge is dull.
Over the years we have settled on two steels that we feel give the best all around results in our knives. One is a high carbon steel and the other is a stainless steel.
We use AISI 1095 high carbon steel in our Old Timer knives (except where noted). This is a very traditional cutlery steel which has a carbon content of between 0.95 % and 1.05 % .1095 steel is famous for both its edge hold ability and resharpening ease. One of the characteristics of this steel is that it will darken or discolor with use, especially if used on meats or fruits. Care must also be taken with a carbon steel knife in order to prevent rust. The blades should be kept dry and lightly oiled occasionally.
On our Uncle Henry line and Heritage line we use AISI 440A stainless steel. Knives with this steel will have a Schrade+ in their tang stamp. 440A gets its stainless properties from the inclusion of 17% chrome with 0.7% carbon in the steel. We have found that 440A is equally as good a cutlery steel as 1095, as well as having the added benefit of a high degree of stain and rust resistance.
Typical chemical composition of 1095 and 440A are given below.
Steels Used in Schrade Knives- Chemical Composition
1095: Ladle (Sample)
Limits (%)
Carbon Magnesium Phosphorous (max) Sulfer (max)
0.90-1.03 0.30-0.50 0.040 0.050
440A: Ladle (Sample)
Limits (%)
Carbon Chrome Magnesium Molybdenum Phosphorous Silver Sulfur
0.60-0.75 16.0-18.0 1.00 0.75 0.04 1.00 0.03
Liners (or Scales)
The handles or covers are riveted to pieces of metal called liners or scales. Most Schrade knives are made with solid brass liners that will not rust.
All knives have at least two liners, and multiblade knives may have more. Liners in the middle of a knife separating it into partitions for housing the blades are called "center liners" and are usually made of the same material as the two outside liners.
The Handle (or Cover)
The handle of a knife is called, in trade phraseology, a cover. In Schrade knives the materials used are as follows:
Delrin® A durable material which will not break, chip, swell or shrink
Staglon® Saw-cut Delrin to simulate Stag, shock proof and unbreakable.
Bone Shinbone of beef cattle, dyed various colors and cut and shaped to size.
Blade Terminology
Over the years the cutlery industry has developed a nomenclature to describe the various parts of a pocket knife. The following vocabulary of words and phrases pertaining to blades is generally accepted within the industry:
Edge The sharpened side of the blade.
Back The side opposite the edge.
Tang The portion of the blade below the shoulder and the part covered by the handle which contains piercing for the hinge pin on which the blade pivots. (Varieties of Tangs)
Point The tip of the blade. (Sketches)
Nail Mark(nail nick) A thumb nail groove cut into the blade so it can be opened easily. (Sketch of Nail Mark)
Choil The angle at which the edge flares away to the tang, which allows the full length of the cut edge to be sharpened.
Kick A projection on the front edge of the tang, on which the blade rests in the closed position, which keeps the front part of the edge from hitting the spring.
Swedge A bevel on the back of the blades.
False Edge A section on the back of the blade is sharpened a short distance from the point.
Full Tang Bevel A bevel running to the entire length of the blade, full to the tang.
Mark Side The side of the blade with the nail mark. (Sketch of Mark Side)
Pile Side The reverse side of the blade
Tang Stamp The imprinting of the manufacturer's name and style number of the knife on the tang usually found on the pocket blade in a multibladed knife
Pocket Blade The largest blade on a multibladed knife. (Sketches)
Pen Blade The smallest blade on a multibladed knife. (Sketches)
Crink A slight bend at the tang in a multibladed knife which permits the blades to miss one another when closed, and all close properly. (Sketches)
Hunting Knives Terminology
Like pocket cutlery, hunting knife terminology has developed over the years and is used in the Cutlery industry when discussing knives. The following is a basic vocabulary pertaining to hunting knives:
Balance The proper weight in a knife, correctly distributed between the blade and the handle. Proper balance simply means that the knife feels and handles well for its intended use.
Bevel The sloping areas which fall from the spine or thickest section of the blade toward the edge.
Choil The area immediately in front of the guard at the bottom of the blade, occasionally shaped to accept the index finger to facilitate a more secure hold on certain types of knives.) The choil allows the full length of the edge to be properly sharpened.
Escutcheon (or shield) A small metal on the handle which can be used for engraving the name or initials of the owner, or merely for decoration.
False Edge A swaged or ground area on the back of the blade, running to the point, which gives the appearance of a true edge when viewed from the side. Sometimes used for heavy work like chopping or hacking or other cutting that might be damaging to the cutting edge.
Guard A separate piece of metal affixed to the blade in front of the handle to keep the hand away from the sharp edge while cutting.
Hilt The handle section including the guard and pommel.
Pommel (or Butt) The end of the handle and usually a separate piece of material shaped and blended into the handle.
Hollow-Ground Blade bevels that have been ground concave in cross section.
Obverse Side The front or display section of a knife. (To be properly displayed, the knife should be pointing to the observer's right, edge down.)
Quillon That area of the guard which extends out from the section surrounding the tang and forms the protective shield for the hand.
Ricasso The flat parallel-sided section of the blade between the guard and the beginnings of the bevels. It is the area commonly preferred for the maker's mark.
Scales The slabs of handle material which are attached to the sides of the tang to form the handle.
Tang The section of the blade shaped to facilitate the fitting of the handle. A Square Tang is the full width of the handle and is designed to accept the scales which are pinned or riveted in place. A Round Tang is shaped to pass through the guard and through a hole drilled lengthwise in the handle. (Varieties of Tangs)
Springs Theory
On the back of a knife will be found the spring, which holds the blade in the open or closed position. It is essential that this spring be properly heat-treated so it will be neither too stiff, too soft, nor too brittle. The portion of the spring on which the end of the blade (tang) rubs when being opened is called the "walk." The walk must be smooth, otherwise the blade will grind when being opened or closed, and the knife will have poor or rough action. (Open the blade on any Schrade knife and you'll notice how well smoothed and clean the spring is.)
Springs are made either single-end or double-end, depending on whether they're for a Jackknife or a double-end knife (Sketches). A knife that opens smoothly and whose blade snaps into open position with a lively click is said to "walk". When the blade snaps shut similarly it is said to "talk": All properly adjusted knives are said to "walk" and "talk".
http://www.rangercamping.com.au/Knives_Handbook/Knives_Handbook_Blades.htm
Someone here a bit more versed in computer work can probably do a screen capture and bring this in here in better quality, but heck... this is worth every penny you paid for it at least!
Codger
This catalog reprint was done with Schrade's blessings by A. G. Russell in 1971. I have no idea just how many were printed, or how many survive today, but they are invaluable resources for any serious Schrade knife collector. Not only do they show the various patterns offered and describe them in detail, but give general cutlery education information, and... key information on the numbering system. Since early Schrade Cutlery Company (now known as Schrade Cut Co after the early stamps) did not actually stamp the often long pattern numbers on the knives, a catalog reprint such as this is our only hope of putting names, numbers, and dates to early knives. Unless you have them all memorized like LT that is!!:D
Codger
As you scout around for this reprint catalogue you should be aware that you may very wll come across an original. Here are some of the rather obvious differences. the Reprint has Catalogue E and supplements the originals only Catalogue E ( at the top ). The original cover is a different color than the Russel reprint. The reprint also has Reprinted by AG Russel. At the bottom it has Reprinted by permission SCHRADE WALDEN CUTLERY CORP. Ellenville N.Y. The reprint also has a 5.00 dollar price in the right corner. There is no price on the original ( since it was free )The front pages ( if the cover is missing ) is also a bit different and the reprint has an introduction by Russel.
. Actually the differences will be obvious the thing is to be aware of what you have if the seller is not moving on price and you have an original you might want to meet his price. Originals in good shape have become rather rare. In fact the reprints are even hard to find. LT
Thanks for the added info, LT! I had not seen the originals anywhere. What did the covers of the supplements look like, or were they just insert pages without covers?
The title of this now familiar catalog, "E" begs the obvious question, was there an "A-D"? Likewise, was there an "F"?
I was told in a conversation a while back that the person might have a 1922 catalog, but that was from memory, and it could well have been the 1926 original. No confirmation on this yet. But you see, this stuff isn't really just "minutia", or "chit", it is the detrius of history, particularly the one company / lineage of knives and workers that consume our interest. Even extending to papers and photos right up until the last gasp in 2004. At risk of sounding like a mushroom eating Jedi / Smurf / Laird from the Hinterlands, the legend and legacy of what was Schrade continues, inviting us to explore and " to go where no one has gone before."*
(* adapted from a White House publication of March 1958 "Introduction to Outer Space" which contained the lines "the compelling urge of man to explore and to discover, the thrust of curiosity that leads men to try to go where no one has gone before.") :eek:
You don't have to convince me I have buildings full. I am the only guy who thought enough about it to risk life and limb to save it. In fact up until recently I was just about the only one who did care about it. Which is why I have it. LT
As can be seen in the scans I posted, my copy was poorly glued and the cover came loose before I acquired it, then the pages started unhinging after a few viewings. That is why it is hole punched for a three ring binder. So about 2,500 were put into circulation. That you went to the trouble to have them made was good though. I'll bet that you didn't have any idea they would be so useful (and in demand) thirty five years later! Is there any chance you would consider a second printing today? Maybe even in binder format? There are a whole new generation of Schrade collectors today, and I don't have to tell you the dirth of research resource materials we have available.
Always a pleasure to have you stop in here!
Codger
Codger
I sold several hundred of these to Knife World, are you sure that they are sold out?
A. G.
http://www.knifeworld.com/outofprdabo.html
It took a bit of searching (for the uninitiated like me), but they do list them. Alphabetical 'S" way down this page of out of print books. I didn't e-mail them to confirm they are still in stock, but KW is pretty proficient about noteing when books are out of stock in their listings.
Thank you again!
Codger
I have a lot of requests emailed to me asking me to "sell" copies of all of my materials, and I have to explain that it just isn't possible. Even if I could, most people don't realize all that it encompasses. And my gleanings are meager compared to quite a few collectors here on the forum. This forum, and the Schrades-R.us site (link at the top of the page) are where we share our resources of materials and knowledge. I ask you, has anyone calculated how many pages would be required to print just the posts in this forum and it's archive? That alone would fill a five drawer file cabinet, I am sure. Just the photos I alone have posted here consume twenty four web pages on my photo hosting service. I'll not post a link here, but anyone with an inquiring mind can easily find it. My gallery there has sixteen photos on each page. And that is less than 1/25th of the pictures in my photo archives. Learn to use the forum archives here, and to do searches of all kinds in the search feature. You'll be amazed at the wealth of knowledge given here.
Codger
I've managed to pick up a few copies of this book.Four are A.G'.s reprint,of which 3 are like new and the 4th is starting to unhinge.
The 5th copy is an original and cost me some $$$.It has a grayish tan cover and instead of having the square,bound spine like the reprints,it is stapled.The covers are dirty and the front one has a sticker residue,but is tight and clean inside.
In the supplement section,it has the first undated supplement(which the title page in the reprint dates as 1928),like the reprints,and the 1930 and 1932 Supplements. Since the next supplement in the reprints is the 1934 Supplement,this on apparently was published in 1932 or 1933.
schradee
schradet
Since LT's cover just says "Catalog E",it was evidently an original 1926.
Ron
I often sell original Schrade materials. I do this for several reasons. the first being that if I have 100 or a 1000 extra copies of brochures or artifacts stamps dies ect I feel collectors who have an interest should have an opportunity to obtain these pieces of history. As some of you might know I often put extra items and include as much as I can in the packages I mail to buyers. Also when I am visited I usually offer as much material and access to material as I can. I believe Larry can attest to that. Again I usually do not sell anything that I do not have back up usually a lot of backup of. This is hard for some collectors to realize since the usual state is to acquire one copy or piece of history of something if they are lucky. it is difficult for these people to be able to understand this. As you may know I have been trying for many years to start a museum I will not go into just how much legal and other problems have been encountered. In order to further this effort I maintain a private museum to keep these items for posterity. Most people do not realize that this endeaver which includes buildings, temp control, Insurance, alarm systems, and my cost of lecturing and promoting the idea ( usually I get a free lunch sometimes not even that) ect, cost money my money this is another reason why I on occasion sell some of the overwhelming amount of duplicate material I have. I have in the past contributed hundred of pictures to Larrys great site as well as trying to do as much for the forum as possible which I started doing when we had about 5 people who ever posted or read the postings. I am mentioning this simply to explain and enforce what Micheal seems to be saying. In fact we are all trying to preserve this history and have our own reasons and needs for our actions and goals some want to write historys and books some want to preserve actual artifacts some want simply to let those interested have access to the information. I just wanted to clarify my position my agenda and reasons for my actions. It is great to look at pictures and read statistics however promoting an interest by being able to own an actual part of that history like an original brochure to go with a specific item or issue I feel makes it a unique display and increases this interest. It has been hinted or alluded to in the past that I should do more, contribute more since I have so much. Well frankly I have done all I can and what I have found is that when these people get what they want it is usually for there own agenda. LT PS should you be in the area stop by.
Having been on the receiving end of LT's generosity I would just like to thank LT for his passion for Schrade history and his willingness to share his "extra goodies" with other collectors, even small time collectors such as myself.
Thank you LT.:thumbup: :thumbup:
Dale
I second what orvet (Dale) writes. LT really is the keeper of the stone, and a generous one at that. Most of us here are very generous at whatever level we can be.
Mr. Russell, thanks for dropping in! The reprint you are responsible for is one of my most valuable Schrade resources.
And there is this, guys.. which is appropriate as we approach Memorial Day:
http://www.thewarontroopboredom.com/
Phil
