Schrade LB7 collector hint of the day
Codger_64
Moderator
I thought I would give you fellows a headsup on some important information that I learned today.
I've had an LB7 for a while now, one of those knives I bought from my local dealer, examined, played with a bit, then cleaned, put it back in the box and stored it for reference. In the past few weeks, I have been doing research on the pattern, and acquired several...early (#0326), mid (#Q81829), and still later, plus a few SFOs like the Harley and commems like the gold filled Gant. I've looked at them, then stored them until the rest of the examples land in my box.
Today's knife was the Q81829, and I was surprised. It is a three pin, no UH stamp, so it is an older one (serials seen so far go thru BB56321). But the knife was in near mint condition.
Of course I had to get it out when I got in my truck still in the post office parking lot and check it before I drove off. Now, one would think that a knife guy, let alone a knife guy with engineering experience, and one who does geometric calculations as a part of his livelihood, would know to figure in the arc of swing, the force of propulsion by spring, inertia etc. and keep his dayum thumb out of the way when closing a lockback, particularly a Schrade LB7 with factory edge and a strong backspring. I don't know what to say except that the object in motion had sufficient inertia and propulsion combined to zip through the tough calluses on my thumb without hesitation. Kinda like a papercut it was. So there I sat admiring how cleanly and effortlesly the blade cut. Lucky for me, there was just the barest tint of red, no major vessels cut. And thankfully no witnesses. I wouldn't tell you except that I hope you will learn from my experience and be vewy, vewy caweful when toying with your new LB7s.
Codger:o
Codger; I really wish you hadn't made that post. We can now all look forward to the environmentalists and OSHA folks lobbying for legislation for the attachment of suitable warning labels not only on the boxes, but on the knife blade (similar to the Sturm Ruger warning on the BBL of their guns). We can further expect to have at least all our LB7's, if not our entire collections, to be recalled to be retro fitted with the new safety labels, and all because you chose to share your very unfortunate and painful incident with us.
Paul
I'm glad you are man enough to admit that. Now I can admit mine. :D
While taking pictures of my Imperial "Super" razor blade stainless knives, I found out how "Super" the blades were. As I opened the blades on one, I lost my grip and my thumb slid right up to the othe open blade. Luckily, no one was around to laugh at the "knife guy" :rolleyes:
Glenn
I guess I'll add one! It wasn't a Schrade, but I have a Case Seahorse collection, one of which USED to be kept in it's fitted box, with the blades open. When I took it out the first time a year or so ago, the main blade, a big heavy sucker which it seems was right on it's snap shut point, did just that, slicing my finger longitudinally, as it ran, not walked, home! When I stopped the bleeding, I cleaned the knife and put it back in the display box. How easily we forget some things- - 3-4 weeks ago I did it again :o !
have we come up with another test for stainless or not?
I know blood will stain a carbon blade fairly quickly. At least my own did.
:D
TTYL
LArry
Man, I thought I was the only klutz kollector here. And then there was the time my everlastingly sharp Sharpfinder went thru the back of the sheath when I replaced it while watching the second deer walk by after field dressing the first. I see now why sheaths are never worn front and center. Bad enough piercing you hip, but....:eek:
Codger
I keep a small legal pad right here by my computer, to jot down notes. On this particular day, I was taking pictures, and had two open knives sitting on the pad. Upon taking a little break from my exhausting task, I decided to open a piece of mail. Reaching for the furthest of the two knives because it had the longest blade, I lifted it up to use it. Well, that's when the fun started, as the tip had gotten lodged under the top part of the pad, (where you tear off the paper), so as I sharply (not so sharp?) lifted the knife, it in turn caused the pad to act as a catapult. I watched in glazed amazement, as the second knife appeared to do two perfectly executed 360s...and drop point first into my thigh. Nothing like STICKING the landing, as they say.
Sigh.
Bill :o
Most of you know that I managed a cutlery store back in the 1980s & early 1990s. I also managed two other stores and my duties took me to the other stores for extended periods. I would invariably end up working in the Salem store which was mostly cutlery. There was always a readjustment period when I returned to the cutlery store on a daily basis. For the first week I was never too far from the band-aid box.
I always had to make sure we had a full box of band-aids when we started training a new employee.
When you have a couple hundred Schrade's, Kershaw's, Gerber's, Al Mar's, Benchmade's, SAK's and others laying open in a display case and you reach into said case a couple hundred times per day.........your gonna' bleed! :eek: It just comes with the territory. :D
Dale
I thought that a box of Bandaids and a bottle of peroxide came with the collectors kit.You need a certain amout of cuts to get your badge.Arnold
Cutting your finger is one thing, but Thigh MumblyPeg???
I flinched reading that one Lobo!!
Well, I'm pleased to have been able to share my story as a perfectly "Bad Example" of handling cutlery. :o
Thank goodness the thigh is meaty...it still bleeds profusely however. :eek:
Bill
