i just got a fine scotch brite belt to try getting a satin machine finish on my blades, but i seem to have some issues with using it. I am getting some weird scratches along the edge, and the same scratches (more like dots) on the opposite bevel which isnt even contacting the belt.
Does anyone recognize this problem, i tried on a couple of test blades using different pressure etc, but it seems to show up no matter what.
Could it be wrong angle? its a bit different finding the flat on a spongy belt.
Also as you will see in the image there are some angled scratches on the bevel, but i think that was just me being sloppy.
Im still very much a noob grinder with only a couple of test blades under my belt so dont discount any seemingly obvious problems.
The test blade is mild steel ground to an a45 gator belt finish before the fine scotch brite belt.
