- Jun 10, 2011
A few questions to those that own Scott Cook Lochsas.
Is there any marking or way to determine which blade steel you have?
The birth card for my Lochsa is long lost but not forgotten.
It acts differently than any other s30v steel that I've used which could be two things, better heat treat or it's s90v
I've come to terms that I won't be getting a take-down tool for it, so I had to make one! A vice grips and an automotive clip expander tool does the trick!
Upon disassembly I noticed a few things:
1: There is a tiny drilled dot (which is kinda like a micro detent mark) on the one side of the knife under where the pb washer rides kinda where CRK marks an "s" for s30v
Do any of yours have this mark or something similar and if you have either an s30v or s90v could you/would you check this out? Maybe one is for s30v and two marks is s90v, I have no idea.
2: On the other side of the blade where the pb washer rides it appears to be hammered like my ring, not sure if you can tell in the picture I tried my best to show it.
The weird thing is that it is only on the one side not the otherside that has the tiny detent mark.
I doubt it had any crap under the pb washer because the washer is perfectly intact and it would have mauled up the washer not the hardened steel.
Do any of your have this "hammered" appearance under a pb washer??
Final thoughts:
I find it pretty cool that the pivot and pivot screw are entirely made of titanium and that the pivot bushing is actually pb just like the washers, which I think lends to the smoothness of this folder.
I get such joy from using my Lochsa and hope it lasts my lifetime.
Final thoughts:
