When I got my Shaptons one of the next things I did was to cut these pieces off my old (American made) Nortons just for the purpose of blade polishing. Using the end like an eraser. I planed to work through the grits. I have done very little of that, partly because I discovered coarser grits work better on broad surfaces unless I really want to go for a mirror which isnt my thing right now.
I do use these for sharpening small knives by hand though VERY HANDY !
Pun not intended.
In the past I have used wet / dry paper in various grits wrapped around a soft rubber block for mirror polishing the sides of blades. The nature of the abrasive in wet / dry lends its self to scratch removal / polishing and healing (think BURNISHING) the surface as apposed to material removal which it sucks at big time. Zirconia is much better for stock removal but is very scratchy. I agree the wet / dry or other hand rubbed methods take a lot of work.
In the end I wish I had little cut offs of my coarsest Shaptons and that would be all I need. Maybe some day I will get brave enough to cut those stones.
Jim,
Thanks for the info on the pads you use. I might give those a try soon on a blade I just thinned.
Supratentorial,
I would rather have scratches than resurface or thin out the blades.
Trust me; unless you have a Phil Wilson that is already super humanly thin there isnt much chance you will do any significant thinning with these hand rubbed methods.
I just took a half mm off each side of the spine of a knife and 1/4 mm (10 thou) off each side of the edge just behind the edge and it took a power grinder to do it. I wasnt getting anywhere fast with even a 250 grit brand new diamond file a foot long. Anyway I have yet to meet a knife that was too thin; especially near the edge.
I say descratch away to your hearts content.
