Screw for my REKAT
Blaid
Platinum Member
I have a REKAT Sifu that is missing a screw out of the handle. Does anyone have parts supplier suggestions to get a replacement AND should I use locktite to keep it all together after i replace the screw?
you might try www.knifekits.com I bet if you contact them they can hook you up. If I were going to use lock tight I would use the kind that still allows you to remove the screws if you need too. Good Luck.
If you can figure out what size the screw is, Olander's is a good source. I've gotten 1-72 ss button heads there and they have a lot of metric stuff. They used to supply alot of stuff to the aerospace industry (Lockheed is within a few miles of their store). They also have a very good staff there. I've taken parts that I had no clue what it was called and they were able to match it.
You could always try to contact the maker, they may just send you one.
Ric
