- Dec 29, 2016
So, i've quickly learned the importance of really good layout lines, especially for a serious rookie like myself. As i've fallen deeper down this hole - i've upgraded my scribers, the most recent acquisition was a high gauge with a carbide scriber. The question i have is how do you guys scribe a tapered line on your tang (or in my case here, the swedge)? My best guess after thinking about it would be to shim one of the ends up, and make sure it was in the exact same place using something like feeler guages on the surface plate. If there is an easier method, or you have some cool tool that you've found, please expand about it here
Pictures of the layout for this progressive swedge i was thinking about how to layout (i'll do more, and this time i'll shim and create a tapered line to follow exactly so i'm not going back and forth trying to even areas out by eye).
Hand sanded the spine out and removed the two lines i had here, which set the tip thickness i was wanting. Would prefer a tapered line though, and just started putting thought into how to produce that.
