Just attempted to re-profile my mini recon1 drop point. Well, didn't go exactly as expected, but I learned a few things... and salvaged it at least
Went too shallow at first and couldn't grind away enough material to raise a bur at the tip. Learned, that since edge to spine angle at the tip is much wider than the rest of the blade, I was grinding too much material and the bevel at the tip would have been huge if I ever got there anyway.
So, okay, my 17 degree reprofile didn't work, lets call it quits, clean it up and just sharpen the edge at 20-22 degrees...
Came out good. Bevel is a bit wider at the tip which is due to physics when using a fixed angle system (learned that here!). On one side of the blade the cutting edge and point where the bevel meets the blade isn't quite parallel, but i can fix that next time. Just need a few extra swipes in that area to even it out. Really really sharp though. The removing of material at the front, ground away some of the black finish there, actually making it look kinda cool. Thing slices paper by just being near it. hahaha.
And if someone asks, i just say i removed some material at the tip to make it thinner behind the bevel for better slicing
So, enough history and on to my question. Where the bevel meets the blade, it's not as... crisp... as i see in some people's photos on the site. Kinda hazy where the bevel and blade meet... almost scuffed. Is this due to the mud buildup on the stones as I sharpen? All the stones are nice and flat (no light shining through when I hold two stones together... except for my 120 grit) and i constantly wash them off/rotate end to end while I sharpen. Not really sure why I can't get that super crisp bevel to blade meeting point.
Any advice of things to watch out for? Is this a common issue for beginners? Will it clean itself up over time and touch ups w/ the 600 and 1000 grit stones? Too much pressure? Too little pressure?
TIA guys!
TIA guys!
