Originally posted by ALIass
Well here goes;
The knives tested was: Boker A-F Black, Eickhorn KM 2000, Glock FM 81, Hill Knives S.O.K., J Rodgers MOD 4,Ka-Bar Next Gener.,J-P Peltonen M.95 and SOG Seal 2000.
The tests;
-Cutting test of Polypropylen rope. Different ways and pressure. NB;This (Cutting test) and Edge retention is under the same testpoints..
-Edge retention. A massive iron rod (27mm thick)is dropped from 50cm hight right down on the edge...(9)
-Grip security.The strenght of the handle. How much can it take before braking loose. Vertical and sideways tests.(8)
-Tip strenght. The tip is fastned and then the knife is pulled until the tip breaks or bend. The tip will be pulled with a max of 500 Newton and untill it is bend in a 45degree angle. Another test the blade is pulled to 30 degress and then released to see if it will return to normal by itself.(9)
-Corrosion test. 36 Hr´s in saltwater.(10)
-Price. Is the knife worth the price?(7) The German price is 300U$.
-Sheath. Quality and function.(9)
The Seal 2000 scored 52 points out of 60. The different points is the ones in the ( ) after each test expl.
The Ka-Bar came in second and the Eickhorn came in 3.
If you want to trade a Seal 2000 (For testing in the Danish waters) I´ll send you the copy of the mag. I have....
Take care,
ALIass
