Sealing Pick N Pluck Foam? (Pelican case foam)
So I'm using the pick n pluck foam from a Pelican case for a custom case. Using M3 77 adhesive spray where the foam meets foam. But is there a way to seal the top of the pick n pluck stuff? I've seen plasti dip mention somewhere use on the top. Is plasti dip the way to go or are there other options to seal it?
I saw a photo series where they used that spray sealant that gets hawked on TV. You know, the one where they put a screen door in the bottom of a boat and then spray it with this stuff:
[video=youtube;ofMwxrWDUmQ]https://www.youtube.com/watch?v=ofMwxrWDUmQ[/video]
Seriously.
Dab a little CA glue strategically, that will do the trick. Just leave the case open and let it dry before sticking your knives in it, or you will end up with pick n' pluck handle material.
