Seb studs on Umnum? possible?
I like the umagooma, um.. I mean the umbrelluma... no... what was that name??? :rolleyes::D:foot:
Anyway.. I like the knife, but I've always really liked the Sebbie thumb studs.
Does anyone have any idea if such a custom order might be possible? :confused:
thanks!
Sebenza studs are for opening the blade. Umnumzaan studs also serve a blade stops. Their is no stop pin on the Umnumzaan. Hard to see how to swap studs without also providing another stop pin.
thanks!
Nope, the Yum-Yum's :D.. studs are pressed in, as it is one solid bar. The Sebenza's stud, or studs are turned down then pressed into the blade.
So the hole on a Yum-Yum :D.. Is a lot larger than a Sebbie hole. Another option may be to find a master Pimper' to custom make you a sebbie-ish bladetop/stud for your Yum-Yum :D
But I got to tell ya, I LOVE the Sebenza's studs.. but the design of the Yum-Yum makes the fatter round studs work very well. You just slide your thumb up the cut out in the scale, and get behind the stud and push and the smooooooth action flips the blade out like it was a AO powered knife :D
