Great tip.
Do you recommend loc-tite as soon as you game it? I just carried it for the first time yesterday.
Mine came from the factory with the stop-pin loctited (or screwed in very, very tight) to the lockbar side. I have never removed it to see which it is, but assume it is loctited. If you feel you must remove it, you can scribe around it with a mechanical pencil or thin sharpie to mark it's orientation. Both sharpie and pencil will rub off, so they provide a temporary reference for it's orientation.
Some things to know about Loctite:
1 - Use the "purple" low-strength stuff. Loctite is reasonably standardized between the various companies who make it (sell it / re-package it etc), including the Loctite company. Typically red is 'permanent', blue is 'strong' and purple is 'low strength'.
2 - Loctite will only harden in the absence of air. This is why the bottles only come half-full as they would harden if they were totally full. It has to do with an exchange of chemicals to the atmosphere that keeps it liquid. Without that going on, it hardens.
3 - Congratulations!!!! you own a 100% metal knife (with a tiny bit of ceramic)!!!! The Loctite is not going to affect the surfaces of anything, but you want to keep a very small amount just on the threads, but if you get too much, just wipe it off. Try of course to be tidy and keep it off the washers etc, but in general you can do some trial and error and not stress out about it. It will not harden where it is exposed and can be easily wiped off. The hardened loctite will come off too. It breaks away a little like a layer of hard plastic. In general, less is more. I sometimes don't bother with any on my 25 and it doesn't seem to matter too much.
4 - Adjusting the pivot is not a big deal. Do not be afraid to screw it up. The Loctite takes a few minutes to set, so you can try the knife, decide if you want it looser or tighter, and then adjust accordingly. It is really a case of personal preference, but ideally you have no lateral blade play, yet the knife is not too tight to open.
5 - the most common error seems to be crushing the tab on the lock-side washer, so take your time. Really you only need to take it apart once or twice a year, but us knife guys like to tinker, so get aquainted with your awesome new blade and don't sweat the details. You can always send it in to CRK if you goof up.
