- Mar 24, 2020
N/A
The "lock rock" on the 31 is actually lockbar flex from the nature of the ceramic ball interface, not lock rock. They still lock up stong as can be and if you're not chopping with the spine you have nothing to worry about. Mine is a more recently built one but someone else on here had stated their new one flexes considerably less than the one they had from the early run.Hey guys, so I am currently debating on ordering a Chris Reeves Knives small sebenza 31 and was curious if the lock rock issues is still a problem. I have knives that are liner locks that have no play and would see this as a major issue considering it is a 375+ dollar knife. Has this issue been fixed or is it still prevalent in the knife today with the later runs?
Thanks, Chris
I think what XL883N was getting at was most, if not all, CRK's flex at least a little when pressure is applied to the spine. I know my three 21's and both Inkosi's flex a little when set on a table and pressure is applied to the spine.They redesigned the lock to use a ball instead of a flat surface and it has been a consistent problem throughout their production. A cylindrical surface is not designed to mesh correctly with a flat surface which creates the issue of lock bar issues and lock rock. It has been an issue on other models such as the Inkosi that Chris Reeve makes. Instead of using the detent ball they could have put a ceramic insert that was flat or used a steel lock bar insert to solve the issue of titanium on steel. Personally I love the company and the design but I am so wary of buying on at all now.
Why would anyone do this and what is the purpose? It does not affect the normal, day-to-day functionality of the knife in any way. It's nitpicking for nitpicking's sake.I think what XL883N was getting at was most, if not all, CRK's flex at least a little when pressure is applied to the spine. I know my three 21's and both Inkosi's flex a little when set on a table and pressure is applied to the spine.
I just got curious when the whole Sebenza 31 lock rock debate started, so decided to check my 21s and Inkosis to see if they had any flex. They do flex a little, as do most of my other folders. It doesn't bother me since I'm not afraid of lock failure on any of my knives.Why would anyone do this and what is the purpose? It does not affect the normal, day-to-day functionality of the knife in any way. It's nitpicking for nitpicking's sake.
