- Apr 24, 2009
Hi,
so I have finally decided that I will keep the small Sebenza 21 I have ordered just a few days ago - the knife just fits my hand, is very well made (reputation, feel) and does not look like a fancy tool unless you know it is
I notice after unpacking, that the edge is consistently dull edge, but though "hey, a few strokes on the Sharpmaker will fix that, so do not worry", well, that was not quite the case.
Just before I took it to Sharpmaker I read a thread here where it was mentioned that the Sebenzas come from CRK with 40deg inclusive edge angle. Even though I plan on putting 30deg on the edge I decided to go go with 40 first and see how that works for me. So I optimistically put on the "standard" brown/grey rods and started sharpening. Since I also used a permanent marker I saw after very few strokes that I am only touching the shoulders of the edge bevel. Aparently the bevel was even larger than 40deg. So I moved to CBN rods. I did not expect this to be fast as I have used these rods to put 30 deg edge on Spyderco Caly 3.5 super blue, but it took me 1 hourh (!) until I could see that I actually made it to the edge. I kept applying permanent marker to see how the situation develops and it went slow - in particular towards the tip. Even now - I am not fully satisfied, but that is probably because I did not have enough patience with the finer rods afterwards.
I know - sharpmaker is really not the tool to set new bevels, but I did not expect to have to do it in the first place. If I had some sort of coarse diamond plate (I actually do in 140 grit, but that one is intended to flatten water stones) I would have used it instead even if I would risk little less even edge bevel.
I have large sebenza waiting for me to decide whether to keep it or not. The edge looks the same as it did on the small one after unpacking (i.e. dull). And while my decision does not depend whether I need to put work into the knife prior its first use, I did not expect that I will have to do it. Should I decide to keep it (it is awesome knife, no question about that), I will surely get that diamond plate to save myself 2h on Sharpmaker.
What I am wondering - is this a 'new standard' how Sebenzas are being delivered? Both knives in question here are dated to February 2015.
Please, do not see this an attempt to bash CRK, I just did not expect so much work to be necessary on a brand new knife from Chris (after all what I read).
