I have a question regarding the lock on the large plain Sebenza. On an old one I have the lock goes about 1/2 way and stops. But on the brand new one the lock will go over to at least the 3/4 or more spot and if I gently press the lock it will go all the way to where the detent ball will touch the far side handle (really the washer). I tried to messure the inside distance when it is locked open as close to the blade as I could and I come up with about .055"
Is this ok? Should I be able to push the lock and have it touch the other side? Right now it has a great lock-up but I am concerned as to how fast it will wear and travel to the far side. I took a messurement the best I could when it was touching the far side and came up with .025-.027"
So you can see here there is only about .030" of travel before it hits. Is this normal or should I send it back?
If any of this is not clear please ask and I will try to explain. I may be worried about nothing but compared to my other Sebenza this one just seems "off".
Keith D.Armacost
If At First You Don't Succeed,
Skydiving Is Not For You.
Keith D.Armacost
