Yeah, and they don't wear like most framelocks.
CRK goes an extra mile and puts an oxide layer on the lockface. Mine hasn't changed a bit since I bought it three years ago.
Sould be about 50-75% of the way across the tang.
Once I mistakenly got some grease on the tang/lockbar interface of my small, and the lockbar was sliding to about 90% of the way across the tang when it locked. That caused it to really wedge the lockbar in, and it grated when I tried to disengage the lock. I wiped the grease off and after a few cycles it was back to normal.
So as long as you can disengage the lock, I'd say you're fine.
When you pull the blade out of your sebenza does the lock bar come all the way over and touch the other handle slab or is there a space? Mine does not touch, there is about a sixteenth inch of space.
