Sebenza Measurements?
Hello all, I'm looking into getting a Sebenza, and i'm looking for the measurements of the handle when closed, and handle thickness of both the large and the small Sebenzas. Would anyone happen to have that on hand, or a pair of calipers handy?
Thanks!
Edit: Ah, forgot. If possible, does anyone have measurements for the standard 21 and the micarta handled versions?
Thanks!
Ok. Here is the best I could do with my cheap caliper.
Large Sebenza Classic -
OAL - 4.800
OAW - 1.150
OAT - .450
HANDLE SLAB THICKNESS - .150
Large Sebenza 21 -
OAL - 4.80
OAW - 1.150
OAT - .455
Large Sebenza 21 Micarta -
OAL - 4.80
OAW - 1.150
OAT - .555
HANDLE SLAB THICKNESS WITH INLAY - .205
I don't have any small Sebies so I can't get those for ya. Sorry.
The sticky doesn't provide the answer to the gentleman's question, nor do the FAQs.
It provides 50% of his answer. Take the over all length (212mm) and subtract the blade length (92mm) for the large sebenza will give you the handle length (120mm). Then apply same logic to small Sebenza
Thank you for the measurements and links. I did subtract the blade length with the overall length, and felt that the numbers were not as precise as an actual measurement. Compared to the numbers provided, my calculations were not as precise, with a difference of 0.09 inches, which is pretty much nothing. I do appreciate you taking the time to help me out, the perfectionist inside of me just *has* to have the right numbers for my spreadsheet.
Anyone with a small sebenza with micarta inlays and a pair of calipers/ruler?
Thanks again!
