I have only handled one Strider, the SNG passaround. Reviews start on page 4.
http://www.bladeforums.com/forums/showthread.php?t=262891&page=4&pp=20
I was not impressed at all. Here's my text from that passaround.
OK, I have a couple of minutes to write this up.
First let me say that I was very much looking forward to receiving this knife. When I first opened the package today I thought Hmmm... not bad.
The good - I like the blade shape, and all the tiger stripe stuff is pretty cool.
But then I started noticing things that seem kinda serious. I'm very surprised no one has mentioned it.
The first and most serious is that when the knife is opened in a regular fashion, then pressure applied against the spine of the blade against the lock, will cause the lock to slip about 1/16 of an inch towards the unlock position. It gives me the impression that someone a little stronger than I could cause the lock to fail in this manner.
I wiped off the grease from the lock face and blade and that helped, also if you use your thumb to push the lock over firmly then that pretty much takes care of it. I don't think it's reasonable to have to push the lock over yourself though.
The blade stops extend out from the scale sides which make it tend to catch in the pocket. If they are really blade stops they should be shaved to be flush with the scales. Also if you examine the scale edges you can see that the lock side blade stop is the only one that rests against the scale. It looks like the contact patch is a triangle approximately 1mm by 3mm.
The G10 side stop doesn't hit, and I can slide two sheets of paper between the stop and the G10. The G10 face is pristine, no dents, no wear, etc.
Also there is a small amount of side to side play when normally opened, possibly due to the blade stops, or maybe it needs the pivot tightened. I tried to tighten it but I need two hex keys, one for each side which I don't have.
I don't like the oval blade hole, companies should pay Spyderco and be done with it. The oval is inferior.
The handle of the butt end does not fit my hand and "pokes" into a small spot in the palm under the thumb. If you look at a spyderco Salsa for instance, the butt end is smoothly curved the whole way. So it matters less how it fits your hand and it's still comfortable.
I'd be curious to know the weight difference between a g10 side and an Ti side. I would imagine the weight difference is very small. I don't see the point of the g10 side. If it's for traction, I think putting rides on the backspacer and adding finger cutouts to the handle would help.
I'm really really surprised, I thought I'd like this knife, and even if the lock/blade play was fixed, I wouldn't buy one.
To my eyes this knife seems poorly thought out or designed, and in this particular knife, has some aspects that makes me think it shouldn't have gotten out of the shop. If I payed $400 for it, it would be returned immediately.
I'm not trying to be a troll, anyone who looks at this knife after me should be able to see the same things I did.
