Let me see if I have this right. The tightness of the pivot screw should not affect the smoothness of the blade action.
The reason I ask is I recently received a Large Regular Sebenza (from the factory) that seemed pretty stiff upon opening and closing. So I did a little test.
I loosened the pivot screw and the action of the blade became easier (smoother). I then tightened it back and the action became harder (stiffer).
My understanding is that the tension of the scales is only applied to the pivot bearing and the blade pivots around that point. There shouldnt actually be any tension placed on the blade, correct?
Or have I got it all wrong.
On my Small Regular Sebenza I can tighten the pivot screw very firmly (without stripping the screw) and it doesnt effect the blade movement at all. I have taken this knife apart and reassembled it many and its fine.
With the Large I have dis and re-assemled it several times to try and get it running right and it just isnt working.
Thoughts?
Thoughts?
