Sebenza Tips
Here are a few tips for Sebenza users. Take 'em or leave 'em, it's up to you, but here's what works for me:
To disassemble: open blade 3/4 of the way, loosen all 3 screws slightly, remove pivot screw, use your thumb to remove spring tension while pushing pivot pin out with the wrench, slide blade and washers out. Disassemble handle further if desired. That's it, it's easy.
To assemble: After cleaning, oil the washers and pivot bushing only, but oil them really well. Insert pivot bushing into blade, put the washers in place on blade (the oil will make them stick), remove spring tension with your thumb, slide assembly into handle, insert pivot pin and replace screw, but do not tighten, just slightly snug. Snug up the other two screws and test function. If it's all good, tighten the back two screws and then the pivot screw. You're done.
Takes about 30 sec to disassemble, 1 min to reassemble. My oil of choice is Breakfree.
Blade scratches: Start out with the polished blade. IOW, order this option, even with a plain Seb. When it scratches, use 1500 grit paper to remove the scratches and then finish with Simichrome if desired. The end result will look better than when your blade was new.
Handle/clip scratches: Don't worry about 'em!
Blade accidentally coming open: Carry the knife in your front pocket, with blade fully against the side of pocket and your worries are over. I've never had one come open when carried this way.
Sharpening: Perform frequent light touchup. For any reprofiling or damage repair, send it to CRK. Unless you're pretty good, if you try anything other than touchup and light sharpening, you'll encounter trouble out near the tip. The edge is thin, but the spine is relatively beefy, even out near the tip. This makes for a real challenge when taking on a heavy sharpening project. I've learned this lesson the hard way.
Other tips: Don't flick 'em, don't loan them to friends, store them in the open position, don't lose 'em, USE 'EM, don't sell them (unless you're using the $$ for another Sebenza), BG 42 is still good (so is ATS 34, BTW), use a belt pouch for outdoor activities (hiking, mountain climbing, etc..).
The above recommendations are just my personal opinions and techniques. One more personal opinion that I firmly believe is that the Sebenza is the finest frame lock folder to be had in the world, at any price. To those who think they're too expensive, that's fine, buy something else that suits you better. To those who hold the same opinion that I do, try the above techniques and you're $300 or $400 will allow you to carry one of the world's finest folders for the rest of your life.
Pete
Farmer,
Thx for the tips.... I have only had my Sebbie for a month and have not had it apart yet. I will give it a go.
As for loaning my Seb out....fogeddaboudit.
Cheers,
Gord.
..the day I opened the box. Nobody would ask me for the loan of my Seb, because it's obvious the answer would be NO!
KR
I don't store mine in the open position and have one that about 6 or 7 yers old. Do you feel there's a change the lock bar will loose it's set?
1.) If you want your Seb lock face to last forever, open the blade to about 60% of it's opening arc, then use your forefinger on the ridges on the back of the blade to fully open the blade while "dampening" the force with which the locking bar engages with your thumb. With daily cutting chores, this is what I do, but when I need a blade and need it pronto, it's opened with full-on force.
2.) For long-term storage, store them open. It only makes sense to take tension off the locking bar, even as minute as storing them open will account for. I've got a few "backups" in my safe that are stored in the open position in Zip-Loc bags with their boxes and all original contents alongside.
While these tips perhaps seem a little excessive, all I can say is consider the source...
Professor.
Talk about obsessive. Yeah I love these things too, but I think your Sebenza's will be around long after you are gone. I wouldn't worry about the lock bar wearing out any time in the near future of your knives. It's fun to think that storing your knives in the open position will prolong the life of the bar; but I don't think it will be any worse for ware if you don't. These things are built like a tank. Chris Reeve himself doesn't mention anything about the wear life of the lock bar and or if it should be stored in the open position.:)
Professor... A few backups stored open in a baggie in the safe? Man you got it bad!:D I'm obsessed with the value and workmanship of the Sebenza, but it is just a tool(a very good tool).
Actually, wouldn't storing it closed help counter lockbar travel, assuming you actually use the knife a fair bit in between?
I think he means by storing it open there is less continual tension on the lock bar.
Fatigue, in my understanding, occurs when something is flexed, so it would be storing the knife open or closed is the same, and the fatigue occurs only when opening and closing. :p
