Hi all first time jumping on here for advice just wanted to ask about an issue I often get. When grinding my edge down before adding the secondary bevel my edge thickness tends to vary. the belly of the blade is generally alot thinner than the heel and the tip of my blade. I often cause more problems trying to thin these areas down to match screwing up the surface finish or blowing through where it's thinner.
I'm trying to work on this for consistency but my questions more in regards to adding the secondary bevel ontop of this. I'm about to buy a wicked edge sharpening system and just want to ask if anyone's encountered this being a big problem if the edge isn't perfectly consistent to begin with does the secondary bevel take on a wavey appearance hollowing out where it's thinner? Or can you just focus on the thicker heel first to get it to shape then work your way up the blade with a consistent looking cutting edge? Thanks for any advice I'll attach a pic of where the edge is currently at
