secondary hardening steel
i have a new steel to play with and the heat treat seems odd to me
aust. temp.2150 soak 10 min then oil quench
tempering
500F 60.5
600 60.5
750 61
950 65
975 65.5
1000 64.5
1025 63
1050 61.5
1100 56.5
all tempering is 2 times by 2 hours
this is a high vanadium SS
i have been advised not to temper between 950-1000
also that it should be next to finished before heat treat as it will be very hard to finish after hardening
thanks
butch
Are you asking a question or making a statement ?? Steels with substantial amounts of V, Mo, W will exhibit secondary hardening . Knife makers temper things like S30V at about 400F .The secondary hardening characteristic is of no real value to the knife.
i was just wandering because of the sharp jump at around 800
and thank you for the response
the folks at crucible say that this steel should be hardened to 63 Rc no prob
Butcher Block, exactly which steel are you asking about. If it is 30v, 90v, 10v or 125V I have used all of them and can offer you the benifit of some hard earned experience. If you are using foil to protect from de-carb then at a first cut make sure it it high temp foil... Phil
ok so now im bummed :mad: or pissed
now im being told that cpms125v is not for sale i just put an order in for my cpm154cm 6' 3v 2' and 10v 4' ,but no i cant get my hands on s125v
going to have to find out how i can get it cause i know its out there someplace
butch
