I did a double edged dagger a year ago, and this is what I did,I took masking tape and taped about 3/8" up from the cutting edge all the way around the blade both sides. then I took fireplace cement that comes in a tube and coated the inside of the blade over the tape edges
, I put the cement on about 1/8 to 3/16 thick, then peeled off the tape, this left 3/8" up from the cutting edge exposed all the way around and on both sides. I let it set and dry for a couple days and then with a hot forge heated the blade until the cutting edges were at critical temp, then quenched the whole blade, the cement came off easily and I had a great temper line all the way around.
It worked good, I've used the cement on several bowies and it makes for a real good temper line and helps keep the longer blades from trying to warp.
Hope this helps
Bill
