brancron
- Dec 14, 2011
Good morning!
First off, I also posted this on the Spyderco forum, but I thought I'd post here as well, if that's OK.
I recently purchased an old Endura from Tactical Elements, and am trying to make sure I've got the right idea as to what it is, exactly.
Here are the photos:
As you can see, it has red handles, says "SPYDERCO" on the show side of the blade (no steel marking), says "SEKI-JAPAN" on the clip side, and has a metal clip marked "US PATENT 4347665."
Am I correct in thinking that this is a first generation Endura in either GIN1 or AUS8 steel, which has had the molded clip broken off, and was then sent into Spyderco to have the metal clip screwed in?
The seller lists it as having ATS-55 steel, but I'm guessing this is a mistake, right? My understanding is that ATS-55 came into use only with the third generation Endura, which had two-position clip affixed by a barrel screw.
And, if it is in fact GIN1 or AUS8, there's no real way to tell whether it's one or the other, right?
I am drawing most of these surmises from information gleaned on the Spydie Wiki (what a wonderful resource, by the way).
Anyways, thank you for any light you might be able to shed. I am a huge Endura fan and can't wait to put this one to use.
