No problem. If I can offer one or two more tips about Ballistol if you have not have much XP with it....
1 - it smells bad. But the smell fades within a couple of hours.
2 - You really don't need to use much of it on the pivots/joints. A little goes a long long way
3 - Try to get a little syringe without the needle to suck it out of the bottle and apply it. The spray bottles are not what you would want in this case and are more for guns.
4 - Using cotton tips, remove the black Emerson grease from all the parts before applying the Ballistol
They say that it is enviro friendly - but I do not put it on any blades I intend to eat with. On those sort of knives I just use a very light coat of "light" food grade cooking oil"
Alot of the trick once your Karambit it lubed is to ensure correct pivot tightness. I chose not to use glue on the threads but have found no "play" in the blade at the tension I have chosen and I have also found that the pivot is not becoming lose.
It is the first time I experienced a folder that felt pretty "stiff" out of the box - but am very happy with it after doing a bit of work on it.
Last but not least don't forget to wash your hands after doing the Ballistol - I would not want to see what happens if you rubbed your eye after messing with it
Regards
A
