I am calculating median grain sizes directly from sieve specifications for the next revision of my grit chart (GLGC) as I have become dissatisfied with the estimates provided by organizations like FEPA and UAMA.
For bonded macrogrits (sieve grades #4 to #220) the coarse limits follow a regularly spaced series. For most of the grits the fine limits also follow this spacing but grits 150, 180, and 220 have an expanded range allowing a finer distribution to pass grading. If for my charted value I take the arithmetic mean of the limits this shifts these three grits in the fine direction relative to their coarse limits.
Are these three grits better represented by the mean value, creating a gap between 120 and 150 despite the coarse limits continuing on the regular spacing, or with a value biased toward the coarse limit, hiding the expanded fine limits allowed by the standard?
For the visually inclined here is a graph of the sieve specifications for each of the grits. For each the gray line represents the coarse limit, the orange the fine, and the black dot (one way to calculate) the mean. The cumulative plot of the particle size distribution of an acceptable grit would be contained in the shaded area between the two lines.
FortyTwoBlades
I am tagging you since you are in the business.
