I couldn't locate any discussions similar to 'semicircle blade, Thin'. So am giving you all a try.
My first question: is their such a thing out there?
My second question: do I need to make my own blades (specs below) and if so, what steel would others recommend. Honing methods also appreciated. other threads appreciated.
I am building something that needs these type blades. I'll need a large number for my own use, so wanted to seek out possibilities before making them myself. Frankly I am hesitant about my abilities in making (by hand) strong semicircular razor sharp blades this thin, though I welcome trying.
Why? I need the thin razor sharp blades similar to a heavy duty utility knife (except semicircle shape). Because I am cutting through a 'wet compressed and then completely dried' material, the thicker the blade (and taper), the less useful it becomes. The material compression and end guides will keep a blade (like the heavy duty utility blade) from flexing or warping. They will be used in a guillotine manner with as much force as is needed to make it through 3 to 6 inches of compressed material.
Size? I will need at least two different sizes, so anywhere from 3 to 6 inches across.
Possible Specs: 0.035 width (possibly a little thicker, say 0.06) and made of carbon alloy steel (suggestions please)
All of your thoughts are appreciated.
ChasY
ChasY
