Sentinel
Lorien
Nose to the Grindstone
Moderator
I think that, perhaps, 'Sentinel' is a silly name. Ironically, it was named by someone who is very serious, (hint: not me😁).
This is the only knife, (I did a couple hatchets many years ago) which I rendered digitally, and then had waterjet cut. Of course, it started out as a pencil drawing like most everything I design and/or make.
The blade is 154CM, heat treated at Peter's, and the handle is made up of a few layers of G10 that I bonded together. It sports a relatively husky edge profile, but it has a smooth convex bevel which cuts really well. It's your standard 400 grit hand rubbed finish, although it's not the best. Adequate, I'd say. I'm looking forward to getting good at hand finishing and have spent dozens of hours over the past couple months figuring out how to do it properly. Still have a ways to go, but I'll get there.
This is a very old project, and part of the reason for that is because I totally screwed myself by having the pin holes waterjet with the rest of it and specified a size which does not exist anywhere in this dimension. I figured out how to fix it, though, and this is the first knife I used corby bolts on.
I think the knife turned out ok, maybe not amazing, but it's ok. I've almost cleared through all my oldest projects now, and this will have been the oldest. I've got some new stuff underway now, so...Sayonara Sentinel! Good riddance!
Whatever the name, you did a real nice clean job😎
Well done mate.
thank you so much!
the fellow who bought this knife was very happy with it and asked, when he saw my 120 square foot shop; "where do you do all the hammering?":rolleyes:
thanks a lot #forgedinfire
Very clean work - the finish looks good (no j hooks in the finish) and I think the name Sentinel is very classy. Wish I'd thought of it!!
Good looking blade, definitely !
I love the lines and it also looks comfortable to use.
Nice hand rub finish on the blade.
What are the three holes in the sheath for ? A clip of some sort ?
TK, that sure means a lot coming from you- thank you!
I guess the name is kind of cool, but I'm weird because I think things that are cool are silly. Probably because I'm not too cool. Just weird 😭
the holes in the sheath are spaced for Tecloc, but I was going to make a neat wrap around belt loop thing attached via fasteners. Then I found out this knife would be spending its life in a display case, so I spent my time doing something else instead
thank you very much:cool:
