Sentry Removal Khukri
After playing with my BAS & 16.5" khuks, it comes to my mind that BAS is not a good choice for the purpose. I think WWII khuk can perform better.
Hope any one of you knowledgable guys can let me know what is the best khuk model used by the Gurkhas for sentry removal. Thanks in advance.
Arya,
I have a WWII but not a BAS. The WWII is truly nice and moves well...it's one of my favorite khuks in the field and the bedroom nightstand. Please elaborate on why your BAS isn't a good choice...curious.
DanR
Callsthunder,
BAS is too small / light to be used to hack the enemy's head effectively. But I am not too sure how the Gurkhas do the sentry removal. I always thought that they would sneak up from behind and go for the neck. If this is the case, IMO, WWII (or any longer / heavier khuks) will do a better job.
I dont think for removing a sentry you would really "hack the enemy's head" I think you would probably slit their throat while covering their mouth and lowering them to the ground...
I've wondered that myself. The F/S is great for this specialty, but if I had just one blade to carry ...
While Khuks are not terribly commonly used to take down sentries in modern warfare, I'm sure it has happened a lot in the past and there must be a good technique and a good knife for it. I'd say go with personal preference. I'd go for my BAS, which is my favorite khuk. Normally, sentry take-downs are supposed to be quiet, right? I've read some about this, and I think that a common tactic used by the Gurkhas was indeed to pretty much chop or slash the neck, ideally in such a way that arteries were severed and the voicebox was destroyed and obstructed, rendering them soon dead and instantly mute. That, if I recall correctly, was from the account of a raid in WWII that involved quite a lot of surprised sentries.
What is the modern tactic for this, not using a khuk? I've heard from different things about special forces that a technique now is to grab the mouth and stab the knife through the carotid artery and into the larynx, blocking any sound at the source. Is that just hollywood or is that reality?
Jeez, what a morbid topic of conversation... Somebody should tell a joke or something. :)
Chris
Grabbing the mouth requires two hands .The kukri will not only cut arteries but damage if not severe the spine causing instant death. The neck is the best target as it's usually unobstructed by gear .I did read of an interesting case of an arm of a Mau Mau terrorist being cut off [the man survived -an example that his "magic" didn't work too well ]
The problem with "slitting the throat" as we typically think of it is the noise factor. This usually will produce a lot gurgling from blood entering the airway. It is best to insert a knife just above the clavicle on either side and then with a pulling motion to the opposite side, slice thru the subclavian, carotid ,and if deep enough, the aortic arch.
Terry
My father spent 6 years in the army far east, 4 of them behind jap lines in Burma with the Chindits in a unit that was 50% Gurkhas.
On gaurd duty hes felt the blade against the side of his neck & a laughing voice say "your dead Johny" as the gurkhas liked to test thier creeping skills the sentry.
He said when you went to swing at the first touch you found one of then had already got a hand on your rifle.
He maintained they would go for neck shot when taking jap sentrys, from the side aiming for decapatation or sometimes a straight blow to top of head , with what would usualy be a mk.2 kukri. {24 oz average.}
i have heard this from many other sources as well.
Both strikes of which are CNS takeouts, much quicker than suffocation or blood loss even from neck artieries.
& after all if the first touch is instant death why risk grabbing someone first? It slower & less effective.
Large kukris are also rather tricky for throat cutting, it also is not the Nepali way,, they dont even cut a chickens or pigs throat, its off with the head evry time.
But sadley today I am told the brit army teaches throat cutting with the little bas.its not realy man enough for the cns oneshotstops. In ww1 it was usual to cut the heads of sleeping germans on night trench raids. {I think cutting was the probably the operative word here.}
Gurkhas have a long history of decapitation both in battle & after as trophys, proof of head count or to identify known terroist , guerrilas etc. { the brits were doing this stuff in Afghanistan & Burma 100+ years ago.}
Spiral
Ever seen the tomahawk khuk?
this was already answerd before but from firts hand account slit throats make ALOT of noise. not only that but there thrashing around everywhere an iraqi i worked on caught a chunck of shrapnel in the throat. opend him up good belive me he made a lot of noise before he died.
peace
doc
'Cause, you know, that sentry might be in a tank. ;)
