"Serrada" is a fighting "art" developed by Angel Cabales. The whole premise of Serrada is "in tight fighting". You can use shortened sticks or regular size sticks or knives or your empty hands. It deals with mid/close range blocking, striking, locking and disarming. Emphasis is on footwork, mechanics, flow and striking power. The feeling is that once you hit mid range someone is going to get hit real fast, or as Angel put it, he would "make someone look like an egg plant real quick". You don't want to be the reciever of the blows so it presses a hardcore flowing attack. "Serrada" is sometimes used to describe the range that "it" takes place in. This is somewhat appropriate however the range should be called "Sumbrada Range". The meaning of Sumbrada in this case is "to shadow" your opponent in a "counter for counter manner". In Serrada the but of the stick (punyo), Abanicos (fanning strikes), Sunkete's (thrusts), Flips, Upward/downward figure eights, Twist locks, Disarms/counter disarms and a flow of 12 continuous blows are used in a very tight structure. Here is how it fits into the matrix of Kali:
Projectiles: Blow darts, spears, throwing knives, rocks (modern day: firearms)
Improvised Projectiles: Coffe mugs, keys, books, bottles or anything you can throw.
Snake Range: Outside of contact range, your weapon hand moves in a very elusive manner to keep it a hard target.
Reverberation Range: The range where the sticks can onely make contact with eachother causeing a possible, deliberate reverberation in the hand causeing the stick to drop out.
Largo Mano Range: The range where the weapnn can only make contact with your opponets hand/arm. This is where you "generally" Defang the snake.
Sumbrada Range: Now you stick can reach your opponents head/body and you empty hand can now punch/lock/disarm. This is where "Serrada" takes place.
Beyond these there is Hubud range (trapping)
Punyo range - butting range - Dumog range - Grappleing.
Hopr this helps your understanding of Serrada.
Demi Barbito
Full Instructor
JKD Concepts/Kali/BJJ
PFS of SLO
www.thegrid.net/pfs
[This message has been edited by Demi Barbito (edited 05-27-2000).]
