nozh2002 said:I doubt that cutting thick rope is better with serration - does anybody tried to test well sharpened normal edge against that things? I may expect linger cutting ability without sharpening, because it is mostly cuts like saw, but kind of cut it makes - limit use significantly for me at least.
I think advantages of serrtion is to make anything cut for sure. Even low end steel will cut the rope if blade is serrated and no need to sharpening.
If you do not cut anything often and don't want bother to sharpen your knife and don't want pay for premium steel - just something inexpensive which may be needed once in emergency situation and shoud cut for sure even in bad condition without maintenance.
Thanks, Vassili.
Pete1977 said:for cutting rope, especially synthetic rope, I find a serrated edge infinately better. It takes less cuts to part the rope, and it retains an edge much better. for example, I've used a PE knife, with a plain ats-55 blade, and an identical knife with a serrated ats-55 blade. The plain edge, after cutting 1/2 inch polypropylene floating rope, used as a groundline for a trawl of lobster pots, took two pulls to cut through the rope, and it was a freshly sharpened blade. It was quite dull afterwards. The serrated blade took one pull to part the rope, and retained its edge almost perfectly.
I tried the same with two knives with blades of vg-10 as well, and had similar results.
I've found that serrations, when sharp cut cloth, leather, rope, nylon webbing, cardboard, paper and other fibrous materials just as well as, if not better than, a plain edged blade. The key is to keep them sharp, but that is true with all knives.
Pete
