To serrate a blade you have to file/grind parallel groves into the edge.If it is not hardened,do this - Take a chain saw file of the size you want and make the first groove.Tape a piece of brass rod the same size as the file to the file.Place the brass in the grove you made and file the next grove.....repeat as needed.If it is a hardened blade you could use a diamond file,but it would be slow going.To touch up the edges after hardening you will need a diamond file or ceramic rod.
