Cliff Stamp
BANNED
- Oct 5, 1998
I had been doing some chopping comparisons lately and my well used Wildlife hatchet wasn't cutting as well as I remember, especially on scrap lumber, I was seeing a lot more compression.
Now the bit was sharp, it would shave readily, but the blade simply wasn't cutting smoothly, so I checked it with a set of calipers and the final edge had steepened to >20 degrees per side, the effects of a lot of sloppy hand honing.
I attempted to file the bit down, but after about ten minutes came to the conclusion that this was going to be far too much work and it was a nice day and I wanted to be in the woods, not on my front step filing an axe, so out came the grinder.
After about five minutes of grinding, and a little filing to clean the edge up, then a honing back to full sharpness, the axe was once again smoothly cutting 2x4's like so much balsa.
Curious, I compared a few times and they were not significantly difference (nor was the stroke count, say 10%), however the feel was very different, much smoother in the cut, a lot less of a jarring impact.
If you are hand honing a lot, especially free hand judging a convex arc, take care once in awhile to check the bevels, I should have done this long before now and it would not have required a grinder to fix.
In any case, great little axe.
-Cliff
-Cliff
