- Feb 5, 2010
I just did a search and found nothing that seems to directly relate to my question, so I thought I'd post a new thread.
I'm working on a guard that I fashioned from a scrap piece of 1095. It's still in a very early state, but I have decided to set some cabochon stones in the ends. I've ordered the stones, which I believe will be low to medium profile stones, hemispheric (flat on the bottom, domed on the top).
My plan is to measure each stone with a digital caliper first. The eBay ads suggest that they should all be 4mm (or 6mm for a second group I bought), but I'm not counting on them being perfectly sized. Then I'll find the drill bit that most closely matches the size and drill deep enough to set the stone, but not so deep as to penetrate through to the matching stone on the other side. I'll then sand and polish the edges of the holes and glue the stones in place.
So to the question... is this the right approach? Or should I drill a hole that cuts through the guard and essentially glue the stones to each other instead of to the metal? Or maybe cut through with a smaller hole so that glue bonds to both the stones and the steel?
Here's another look at the guard in question to help you visualize what I'm thinking about.
BTW, I currently have no use for this guard I'm making... I just want to finish it as a totally separate exercise. And as an aside, the steel is .25 inch thick at the ends... if that makes a difference.
One last thing... should I HT the steel (after I'm finished making the holes, of course)? I'm thinking yes, to help prevent scratching.
- Greg
- Greg
