Setting Up A Grizzly 2x72
My wife just called and said my Christmas present will be here on Tuesday.
I'm very thankful and quite excited. 40 year old child.
Is there anything I need to know in order to set it up properly? I think my parents may be getting me the 10" wheel attachment since they asked me a hundred questions last night as to why I want it.
Congratulations!
Yeah, the graphite platen liner doesn't last long if you're dong much in the way of profiling. It just wears a groove. I replaced it with a pyroceram platen from Darren Ellis (I think Tracy has them, too?).
It may be worth your time to remove the paint from the work surface of the work rest, as over time it will begin to wear/peel and create a non-smooth surface for your work to move on. You can scrape it off with a razor and sand it smooth again. As you work with the work rest, you may come up with ideas/ways to modify it to meet your needs better. That's something that you will figure out as you work and depends upon your ingenuity and skills.
There tends to be a bit of belt wander (tracking issues) on the Grizzly as is the case with most 2-wheel grinders. This can be improved some by taking a length of electrical tape and wrapping several layers around the very middle of the tracking wheel, effectively increasing the crown slightly. I'd try it out without the tape first, and if the belt wanders too much when grinding, give the tape a go.
It's likely worth it to add a small foam vacuume filter over the cooling slots in the motor, as in my model, the slots are right next to the grinding wheel ready to take in all manner of crud and metal dust. I just took a foam filter and taped it over the vents to keep the majority of the grit out.
Mount the grinder so that the grinding wheel and the buffer are clear of the table if possible. That may be a challenge depending on your table size. My Grizzly is mounted so the buffer is free, but I wish I had the grinding wheel free at times as well. It's no biggie for me, and I work around it. With the 10" wheel, you might be forced to mount the grinding wheel side clear of the table unless you add a spacer under the motor/mounts.
If you're grinding hard and your grinder suddenly turns off, it's usually because you tripped a breaker or the safety switch in your power strip. Let it cool down for a minute, reset the breaker, and you're good to go again. Since the grinder runs off of 110V, it's pretty easy to draw enough amps when working heavily to trip the safety switches on most power strips/extensions. See if you can lighten up your work a bit, and you'll be less likely to trip the switches.
Other than that, have fun with it. You'll learn a controlled and gentle touch over time when working with the Grizzly. It runs fast, and it takes some time to develop the control for detailed work. Be patient, and you'll figure it all out. Enjoy it! I've been using mine for 5 years now with no problem, though now it's relegated to handle shaping duties and most of my metal work is done on the KMG.
--nathan
The only thing I would add is that I find that you need to keep a lot of tension on the idler wheel. It helps with tracking. Also, as with any belt grinder, remove the belt when not in use. This keeps the tension spring from weakening. Hope this helps. Have fun.
Springs don't weaken. There is no need to remove the belt.
I prefer the graphite platen, but do most of my grinding on the contact wheel.
Bill, the graphite platen is a nice thing when used sparingly, I agree. It is slick and helps reduce heat build up. It's when you do a large amount of grinding on the platen that it really becomes a problem. Of course, you can buy replacements to the graphite pad if you like them as well. I just liked the pyroceram as it has a more true-flat surface and wears much better.
I haven't had problems on the occasions where I've left belts on overnight. I've not worried about it much with my Grizzly as the tension isn't all that strong. I do, however, remove the tension on my KMG, as it has a stronger tensioning spring and can distort your belts with prolonged tension creating belt tracking irregularities in the stretched out belt.
--nathan
The Griz grinder is probably one of the most loved hated grinders out there. I find it be pretty handy.
I guess you'll have to put it together. Even if it comes all constructed though, it will be worth your time to get a square out and make sure things are square as possible: the tracking assembly to the shaft upright; the length of the shaft upright to the mid bracket/collar; the bottom shaft collar to the arbor. I found I was able to eliminate a fair amount of tracking issues by taking the time to do this, especially the tracking assembly at the top.
It will really be worth your while to set it up so that the contact wheel and belt spin off the edge of your table/bench/stand. You can then put a bucket or basin of water underneath to catch a lot of the grinding waste, as well as have something to dip your steel into to cool as you grind.
Have fun and post some pix when you're all set up!
The reason to remove the belt when not in use is because it will stretch the belt. Aside from deforming, it's my belief that this can weaken some belt splices and cause belts to fail prematurely.
I don't know about you other Grizzly owners but my platen was not flat. I had to put it on a flat table sander to true it up. Seems to have beeen made that way. If you want to fake a variable speed, I have seen folks can fabricate different dia drive wheels out of layered plywood. (but that seems really unsafe). Here is a web page with some Grizzly mods...
http://www.stoneandsteel.net/equip_grinder.html
I would disagree to an extent. Springs, by their very nature will weaken after MUCH repetition of the function for which they are designed. That IS NOT gonna happen in this case. I can't see the knifemaker who could possibly wear out that particular spring by putting on and removing belts. I would still recommend removing the belt, though, because the rubber part of the contact wheel does not have the same "endurance limit" (maximum stress at which any given material will operate indefinitely without failure for a given minimum stress) as the steel in the spring. If a belt were to stay on the rubber contact wheel with the the spring pressure applied, for an extended amount of time, it could potentially distort the shape of the rubber on the wheel. I forget what I paid for my 10" wheel, but I won't take that chance personally. Better "safe than sorry", right? ;)
Possibly, but I have had 2 Grizzlies over the past 15 or so years. I have never removed the belt when not in use, and never had a problem.
Childzplay,
Been there, done that. ;) Weird coincidence ... I was 40 when I got mine! Congrats on the new machine. You'll love it I'm sure. I know I love mine. Just don't get to use it as much as I'd like. :grumpy:
