Ban
Moderator
- Oct 14, 1998
Is the critical temperature for any given steel necessarily the point where the steel has reached a non-magnetic state? I am asking because I want to find out if this applies to all steel. i.e. Simple High Carbon Steel, CPM High Alloy Steel, Air Hardening Tool Steel, etc
The other question pertains to D-2. I have read that it should be preheated at 1450-1550 deg F and then the temp should be raised to 1850-1900 to harden. From what I understand the preheat is to reduce some stress to allow the steel to adjust to the higher hardening temperatures. My question is can you overdo the preheat? The reason for the concern is because I notice that it takes quite some time for a furnace to go from 1500 degrees to 1900 degrees.
