I bought a new 112 (0112CFS2) that uses screws, not rivets, so I know they exist. Wondering if anyone has drilled out their rivet(s) and replaced it/all with screws?
If so, where did you buy them and what diameter is needed? I've been to usaknifemaker.com but don't know if there are other or better places. I ask diameter because I worry that Buck may have changed size of my 0112CFS2 as the sexbolts available may not be the same as the rivets. I'd hate to drill out a good rivet knife and find that out the hard way. My first stop was Buck but it says on their website they don't sell parts
Another reason is I want to take them apart is for mods, which would include lightening the spring and modding the aft spacer so it doesn't flatten the tip of the blade. Or maybe put a stop near the pivot to prevent said contact. You'd think after all these decades they would've fixed that... I'm all ears if others have modded them for those reasons, or other cool mods I'm unaware of.
While I'm here, same question for a 119 if I remove the pin. I want to change the handle on a 119 but figured I'd probably never get the Alum end to look oem after. While oem looks is what I'd like, a threaded fastener that looks nice is a reasonable option. So I was curious how others are doing it... I saw a pix online where a guy welded threaded rod to the tang and screwed a custom end on, but I'd rather not. I'd prefer whatever fastener going thru the oem hole in the tang using the oem butt piece. Any thoughts on it are welcome.
Also, does the oem pin come out with a punch/press or is more of a rivet and needs to be drilled out? Since there is zero play and it holds up over time I assume the latter, but just a guess. Or maybe epoxy is involved, I just don't know...
If there is epoxy in there, is all down the tang bonding the phenolic handle to it? Or is the phenolic poured/cured/bonded to the tang? I can break that handle but if I take apart a wood one I'd rather not damage it, so even if the phenolic doesn't have epoxy, I worry wood might. So any info on that would be appreciated.
I bought a new 119 to sacrifice for this, so no real loss if it's a complete fail. If ti works it will be a practice run for the next knife.
Thanks!
Thanks!
