- Apr 3, 2011
I know a FIF guy who got a TW-90 SG and got rid of it for a standard surface grinder. He said the up-angled pumping was crazy tiring.
Yes.Can't it be run in the horizontal position?
I'm in the same boat... I have a stand alone stone (haric 618) but it takes forever lolYes.
I use it on my kmg. It’s simple for tapered tangs. I have a stand alone unit too, but using the sga is way faster and easier.
Definitely faster on a platen, but then it has to be flattened again on a disc. Probably just as fast either way.It seems all the cool kids are using surface grinders to do tapered tangs.
I glad I learned how to do it, watching the Loveless video, on a 2x72 grinder.
I've used both. The Reeder is much easier and more versatile, IMHO (distal taper, tapered tangs, even bevels).
It is heavier built, and when mounted on the double arm, rock solid.
You can do a longer blade on the Reeder. Fullers are also possible.
Just the smooth and easy side-to-side motion with the handle grips is enough as far as I am concerned.
No, it is a side-to-side horizontal movement type. The contact wheel would have to be on the same plane.Can the reeder be used comfortably on a pheer grinder that only operated in the vertical position?
i use my tw-90 slide horizontal so i can sit-n-surface grind. as far as stiffness, as long as there is no flex between the contact wheel and the sliding table, it will be ok. any flex of the arm between the contact wheel and where it attaches to the grinder wont affect accuracy as long as the belt is tight on the wheel.
I never flaten them on the disc, when I was doing them I had no disc.
I just ground with a glass platen, then a few back and fourth on granite block with sand paper.
Grinding taper tang goes fast on the 2x72
I get what you’re saying. My point was just that with the surface grinder or surface grinder attachment will eliminate that need to go to a granite plate with sandpaper or a disc.
It’s especially quicker if you’re doing batch work.
Definitely a great upgrade if you can afford it.
Is there a link to the Loveless video? Or is it for sale somewhere?I taper on my flat platen like Bob Loveless. They come out flat. I don't need to refine with a granite plate or anything else.
