- Jun 25, 2015
I've picked up a 3" Shamwari recently and eventually took it a part to clean and lube it. I used my CRK grease sparingly when I reassembled it. I also found that I needed to tighten it pretty good so that it had no blade play and was centered better. But it's hard to flip it open with my thumb. Actually wore my thumb out. I know there's a bit of a learning curve to get the front flip to work, but it just seems a bit stiffer than it should be and that makes it hard to front flip open.
So, I'm wondering if there'd be a better or perhaps thinner lube to use rather than the CRK stuff. I've got some CRKs and only use it on them. Works fine but I typically don't flip them open or expect flipping action out of them like I would the Shamwari.
Lastly, this Shamwari has 3 washers. One each side of the blade and there was another under the colored pivot on the lock side. I assume that's normal.
Thoughts, suggestions?
