Yvsa commented:
<font face="Verdana, Arial" size="2">The cheapest and best strop is one you make yourself imo.</font>
That makes sense to me. I would at the least expect a strop that you make for the purpose of sharpening khukuris to be better at sharpening khukuris than a razor strop would be.
So, I think I will try to make some. Here are some ideas for comment. Maybe some of the more experienced folks can save me some grief if my plans have any obvious flaws.
Not being much of a leather worker, I don't have leather scraps lying around, but I have been looking to see what I can find on the net. The most likely thing I have found so far is at The Leather Factory,
https://cart.leatherfactory.com/quikstore.pl ,
where, under "Strips, Straps, Blanks & Buckles" I find plain "tooling leather" straps 3/4" wide by 50" long for $4.49. This ought to be enough for at least 3 strops (and maybe 4) in the sort of narrow width that sounds appropriate for khukuris.
I am sort of planning to glue lengths of this strapping leather to the narrow edge of a 1x2 (which is why I would select the 3/4" width) and then apply a suitable abrasive compound. I would guess that rough side out would be suitable for tripoli or suchlike and smooth side out for fine SiC or CrO.
Another part of the project would be something for the rougher shaping of convex edges, so I am thinking of making what would effectively be a long, narrow, soft-surfaced sanding block out of the same basic plan, but with a means of holding strips of sandpaper in place. Here is what I am thinking of:
I'd want to make it short enough to allow a standard sheet of sandpaper to overlap the ends by enough to be held in place by the clamp. Here's another advantage to using a standard width: I can simply rip a piece of 1 by to a thickness where I can easily use a razor knife to slice off pieces of sandpaper to use.
I'd probably make the strips of sandpaper wide enough to cover the entire leather surface and maybe even hang slightly over the sides (unlike what I show in the pic).
These straps are not described in terms of the weight or thickness of the leather, but they appear to be intended for belts, so the thickness ought to be appropriate for that use. Does this seem like a suitable weight and type of leather for strops? (Especially for strops intended for making convex edges?) Any other comments?
Thanks.
Paul
Paul Neubauer
prn@bsu.edu
A tool is, basically, an object that enables you to take advantage of the laws of physics and mechanics in such a way that you can seriously injure yourself.
