shapton glass 6000
So I got my shapton glass 6000 a few days ago and tested it out.
It cuts fairly fast, but my edges don't seem as scary as when I use my kitayama 8000.
Is the stone suppose to feel rubbery and have texture? When I polish, it leaves orange skin like texture on the glass/stone.
lap it once to remove factory crust layer before first use. Well, at least every single one of mine needed one.
For the type of Sharpening you do there are better stones... I'm guessing this is for your Yanagi-ba? The Glass stones are very good but best on a 50/50 or 70/30 grind found on a Gyuto or Petty.
8k will be a finer polish so if pure sharpness is your goal then stick with the 8k. 6k, 5k, or even a 4K edge might not feel as sharp but they can offer longer edge retention for high volume cutting.
Recently, I was looking for a good finishing stone to use on single bevel traditional knives. I've used a fair number of stones so this selection was not exactly easy, but in the end I found the Suehiro Cerax 6k to fit in perfectly. It yields a nice polished bevel with excellent sharpness but the feature I was after is its ability to smoothly polish the clad metal and produce a nice Kasumi finish. I would recommend it over the Shapton stone for single bevels.
I use the shapton 6000 for sujihiki and gyuto. Yanagi only gets 8000 kitayama.
I have used my sebenzas on the shapton, i think maybe I should of gotten the 12000 or 16000 shapton.
Does suehiro make higher grit?
Why do you want such a high grit finish on a Gyuto or Suji? Big general purpose knives like that need some tooth to the edge, a 2000 grit finish would be my recommendation.
I've tried all sorts of grits for my finish. High polish is just much more clean and fast in my experience (for food prep, not stone cutting speed). My gyuto, sometimes a 4000 is a good finish stone, but usually 8000.
