Share Your Knives And Specs
JK Knives
Moderator
There have been several requests for more info on the different models and handle materials, so here is your chance to show off your knives! Be sure to include what model it is, the specs, and handle material for reference. If this is popular I will contact a moderator to make it a "sticky."
i'll start. :)
JK Bulldog (my design, John's build):
OAL: 8 1/2"
BLADE: 4" of O1 at 5/32" thickness and 1 1/2" height, FG
HANDLES: Contoured OD green canvas micarta
GREAT camping blade. This has just become my ONE and ONLY fixed blade and I'm fine with that. :)
This will evolve eventually into "THE COLLECTORS GUIDE TO JK HANDMADE KNIVES", to be published by Stackpole. and later becoming an Outdoor Life Book of the Month club selection after the Favorite Gathering Recipes chapters are added, along with the chapter on HK knives.
I don't see an issue with that :D
The original Tool...numero uno.
1/8" thick O1 steel, 5" blade.
1 1/8" blade hight.
Rounded spine up to the squared thumb notches/jimping.
Saber grind.
Forge/heat treat finish mostly worn off.
4.5" handle.
Tan Micarta over 1/8" Orange G10 with 1/4" brass pins.
Exposed rear tang with lanyard hole.
Overall bad assness throughout.
Sam's Sway back
JK Sam's Swayback
7" Overall length
3" blade
1/8" thick O1 steel
Saber Grind
Rounded spin
maple burl scales
2 1/8" brass pins and a solid rear 1/4" brass pin (can be hollow for lanyard)
JK Iris
6 1/8" Overall Length
3" Blade
3/32 O1 Steel
Rounded swedge
Saber grind
Walnt Scales
2 1/4" brass pins and hollow 1/4" lanyard hole
Also a half moon space at end of edge for ease of sharpening on the go
HK Mini Pocket Muk
the 1st one
5 1/2″ overall length
2 1/2 cutting edge
3/32 01 steel
Saber Grind
Macadamia Nut Scales
1/8" copper front pin
1/4" copper lanyard tube
HK Pooka
2" blade
3/32 01 steel
Saber Grind
Walnut Scales
1/8" brass front pin
1/4" brass lanyard tube
JK Toby's Knife
I have several of these (Still my favorite EDC!) so I'll just post up about the first one
6 3/4" overall length
3 1/4 blade lnegth
2 aluminum pins
3/32" thick o1 steel
flat grind
epicness laced into every fiber by hand
here's one in ebony with a saber grind
