Shark or Stingray?
ToyKnife
So the question has boiled down to which one should be used as a pocket sheath, shark or stingray? I understand that both are a strong leather but what are the pros and cons of the two? I don't think the sheath will be used as a EDC but that may change.
Any help will be useful.
Thank you.
Just my observations...
I'd go with the stingray. Shark is more abrasive and I would think the stingray would hold up better to being used as a pocket sheath.
SDS
Im no sheath maker but i can tell you I have had a stingray wallet in my back pocket for the last 10 years and the only thing wearing out on it is the cow leather its made out of as well. Its a beautiful material and seems to last for ever. I dont think you can go wrong with stingray.
Regards
Robert
Stingray is about the toughest leather you can get but the surface is very hard and can be abrasive. It is also thin so it needs to laminated with leather in most cases.
The sharkskin that I have is very soft and supple but it is thick and duarable.
For a pocket sheath, the stingray is slick and will slide in and out of the pocket easlily but it could be abrasive tot he pocket material. The sharkskin would be gentler to the pocket but it tends to grab and drag against other material.
If appearance is an issue, I would go with the stingray as it is quite beautiful while the shark is not as attractive---rather dull, in fact!
Would the smoothness of the Stingray hinder the removal of the knife? Would the sheath go with the knife if removed quickly?
And how does stingray/shark compare to alligator?
As to whether the knife will come out of your pocket with the sheath has as much to do with the design of the sheath (how tight the knife fits) as the material used to make it.
Most finished stingray skins are going to feel somewhat slick. Raw stingray skins are very rough and I believe were even used as a type of abrasive sandpaper of sorts by the Japanese. When they are finished out they have a high luster and are available in nearly any color you can imagine and I have even seen patterns printed on some.
Sharkskin is usually a little more rough but can also be finished out to be rather smooth. I believe raw shark skin has also been used as a type of sandpaper as well. Shark has a more dull appearance than stingray but can still be very attractive.
You might try searching some custom holster makers websites to get some ideas of what these two leathers look like on a finished product.
Alligator is a different type of leather altogether. Overall it is mostly slick, or smooth, but with a much heavier texture. The texture also greatly depends on what part of the animal the hide came from.
Your best bet is to try to locate some of these leathers in person so you can get a better idea of what the differences are.
Good luck,
SDS
I regularly use stingray and alligator and have used shark before.None by themselves would be suitable as a sheath.They still need to be overlayed or inlayed onto some cowhide.All three are durable skins with the most durable going to stingray.Shark is usually very soft and supple, as is most alligator except for the back and tail.All three can come in a variety of colors.Dave:)
This is where I get my skins and many dealers buy from them too.It helps that they are about 5 minutes from my shop.Good people.
http://ostrichmarket.com/
Don't have a pic's of any shark right nowbut here are Stingray and alligator
