Sharpen a Mora?
Just got my first mora and I'm a little confused. It's the carbon steel clipper. It's scandi grind, but it also seems to have a slight microbevel on it.
I use the edge pro, sharpmaker, and I have a couple stones. Should I sharpen the main scandi bevel, or the micro bevel? Also what should I use?
Thanks.
so long at the micro bevel is truly micro, you can sharpen the main edge to get rid of it.
otherwise I'd polish the micro bevel and leave the rest alone.
I don't have a Mora yet, though I've been tempted to get one for a good while. The Scandi grind on the edge seems like it'd be prime for my favorite method, 'stropping' on wet/dry sandpaper on leather/wood backing. Wide bevels are so easy to maintain this way. I'd probably do away with the microbevel, and just use about 1000/2000 grit to maintain the main bevel (or, if more 'bite' were preferred, something in the 400-800 grit range).
Thanks for the info vik.
And OWE, edge trailing or leading? And with soft or hard backing?
The 20 degree edge (10 degree bevel) on the carbon Moras is a little brittle so it depends on what you are going to use it for. I have one that I have been using to cut leather that I just sharpen to the 20 degree edge. Others that might see rougher use I put a secondary micro bevel around thirty something degrees.
Mora recommends a micro bevel on all of their knives that are going to be used as a general purpose blade.
If the edge does need a microbevel, that's easy enough anyway. After sharpening with whichever method you choose, a few light passes on a ceramic hone (such as your Sharpmaker's rods), at a slightly elevated angle, will make quick work of it.
