+1 that Sharpmaker is a fantastic tool that simplifies sharpening recurves. I still use mine for that occasionally.
That said, I've moved to freehand sharpening and that's what will get you best results, maximum flexibility, and easier to do it in the field with your hunting knife without need to lug along Sharpmaker.
If you don't have a large number of recurve type blades to sharpen, then for freehand I would recommend a smaller handheld option like this dual grit Buck EdgeTek diamond steel (325/750 grits) for $25. Those 2 grits will give everything you need for practical usage. They also have a slightly more expensive, 3-grit Edgetek sharpener in this same line that would give you a higher 1200 grit option as well. This sharpener has rounded sharpening surfaces so you can sharpen curvy or flat blades, and you can hold it like a steel. When I use my diamond or ceramic steels like this freehand, to hold a consistent angle, I typically rest the point on something and hold it straight up and down, then it's easier to keep my blade strokes at a consistent angle. Also, if you want a helper angle guide, you can get a cone-shaped angle guide and attach it to your steel or your Edgtek, to help hold a consistent angle.
https://www.knifecenter.com/item/BU...-Steel-65-inch-Diamond-2-Sided-Sharpening-Rod
If you have a bunch of recurve blades and want to go beyond a simple 2-grit or 3-grit handheld diamond steel like the Buck, then I'd recommend getting into slip stones. I'd get a coarse Norton slip 180 grit for shaping and edge repair, a finer 600 grit diamond cone for apexing, and then perhaps a higher grit "extra fine" diamond or ceramic steel to finish. That would give you a full 3-grit sequence and could handle all types of steels including super steels. I'd only get into this type of setup though if you have a LOT of recurve blades to sharpen, including super steel recurves.
Here's a example set of 3 sharpeners that can handle, coarse, medium, and extra fine sharpening of recurves, including super steel blades. Notice the slip and dmt cone sharpener both have wider and narrower curved edges, so you can sharpen a good range of various recurve sizes:
Norton Crystolon 6" slip (I'd get the "medium" 180 grit to be your coarse stone)
DMT large cone sharpener:
https://www.knifeworks.com/dmt-diamond-cone-large-fine.html
DMT extra-fine diamond steel:
https://www.knifeworks.com/dmt-12-diamond-steel-extra-fine.html
